for sometime i have been converting svcd to dvd using various programs but i want know ifthere is an easier way which takes less time
what i want to know is that if i get a capture card can i plucg my dvd player into it and capture the video as vob files
like i said i have no experience with capture cards i have never even seen one but would like some basic info on how i use them and what programs to use to make what i capture into dvd vob files with chapters
i have used these forums and learnt about the conversion process without capture cards but would like to know the asics using a capture card and if it is a quicker process
thanx for any help guys and i think this may be the wrong section to post in but i am a newbie as far as capture cards go so i posted here in newbie section
sorry if i was mistaken
So what you really want to do is take the original vob files and back them up to a dvd+-r? y dont u just rip the vob files from the original in your drive. no need to run from standalone to capture card if you have a dvd drive.
You can capture with capture cards in AVI or MPEG. If you want VOBs you need ripping software and a DVD-ROM drive in your computer. But I have never heard of a DVD player that outputs in VOB. If you have a hardware encoder, you can also take your DVD player output and encode it into DV and send it into your computer via firewire, if you have a firewire card installed.
Hello. -
like i said i have no experience with capture crads but from what i just read it seems all i need to do is play my svcds on my standalone dvd player while its hooked upto the capture card and save them as mpg's
then rip the mpgs and chapter them using editing software before burn them to dvd as vobs -
You want easier but I don't know what you are doing currently?
Save MPEG file of SVCD to HD
1. change resolution header to 352x480 using DVDpatcher (entire file)
2. Use movie factory {or other authorware} to make a dvd format on HD (check setting so program does not re-encode)
3. change resolution header to 480x480 using DVDpatcher (entire file) on each VOB created.
4. Burn to DVDR
If you want to join several SVCD into one then between step 2 and 3
delete IFOs
rename VOBs so second set is in sequence
then rebuild IFOs with IFOedit or DVDfab
This is a trick that should work since it sounds like you DVD player is also playing SVCDs. -
thankyou guys for the advice and that small tutorial was kinda similar to what i was already doing bit with a few differences so ime gonna try it out
thanx again guys
Music Guy Seeks Advice
By baton999 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2011, 15:39 -
Conversion advice for a newbie
By darafat in forum Video ConversionReplies: 1Last Post: 20th May 2010, 02:17 -
Possible to encode a Premiere Pro video in DivX format? (total noob seeks advice)
By metathran in forum EditingReplies: 24Last Post: 30th Jan 2010, 21:55 -
Newbie looking for advice.
By mopar339 in forum DVD RippingReplies: 1Last Post: 14th Feb 2008, 02:36 -
By mopar339 in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2008, 02:35
