My problem is... I'm trying to use TooLame with TMPGEnc and TooLame has set defaults to create audio files in the Windows Temp folder on my root drive. I have my c: partitioned small (3 gig) so I can keep the drive defragged and clean easily. All my progs and data are on the d: So I figure I need to create a shortcut to TooLame with the appropriate switches set so that when it runs it will use a folder on my d: Then I can point TMPGEnc to the shortcut. Would that work and how would the switches be written?
I need a little help here. I know just enough to be adventurous but not enough to do it with confidence.
Thanks for any help,
Brute666
This guide may provide the information you are looking for...
http://www.flexion.org/audio/toolame/
Good luck!
short answer. TMPG > options > enviromental settings > general tab > folder settings > temporary file. Select any folder on d:\
laptop switches off by itself
By angryassdrummer in forum ComputerReplies: 14Last Post: 17th Oct 2011, 09:23 -
TV picture switches off
By Mannys in forum DVB / IPTVReplies: 4Last Post: 25th Jun 2011, 11:29 -
Grain Retention Switches for X264
By Soopafresh in forum Video ConversionReplies: 3Last Post: 23rd Jan 2010, 03:48 -
HDMI switches
By stiltman in forum Media Center PC / MediaCentersReplies: 5Last Post: 1st Oct 2009, 22:13 -
DAC-100 dip switches
By Steinninn in forum Capturing and VCRReplies: 0Last Post: 6th Dec 2007, 20:31
