  1. Guest
    Anyone can give me a list of Programs that support DVD-9 projects?
    All I know about is just the extinct DVDMaestro...
    Thanks!
    Jul 2002
    the only other one I know of is Scenarist, If you want it I hope you have a fat wallet, cause I heard it costs thousands ($$)
    maybe there are others I just don't know
    Good-Luck
    "The software said Win XP or better, so I Installed Linux"
  3. Guest
    Thanks!
    To note, money is not an issue...
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    do a search on ebay for seller flounder2002 and email him/her ... they have some copies of DVDmaestro
    dvd pro on mac is maestro now ...
    the new adobe dvd authoring app ENCORE will support dvd-9 also .. http://www.adobe.com/products/encore/overview.html
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    tonnet@sbcglobal.net also has Maestro for sale ..
  6. Guest
    Thanks BJ_M!
    Thing is, I'm a bit afreid of using Maestro... I've tried using a creacked copy (Just to see how it is before buying!), and I found a problem there... When playing on DVD software players, it's reported as if the DVD has 32 subtitle streams and 8 audio streams even when creating just one of each type... The only solution I could think of is disabling the selection of streams from within the movie, and I wouldn't like to do that...
    In any other case It would be OK, but here it's known that no new updates would be made, so it's pointless...
