I am trying to put some boxing fights I have recorded on VHS tapes to DVD. I captured the VHS data into an avi file at a resolution of 720x480 using the Huffy codec and PCM audio. I used virtualVCR for the capture. The result is an avi file of 65GB for an hour of tape footage! Then I tried encoding it into a DVD compliant file using TMPGENC Plus. But when I try to import this large file into TMPGENC, the program stops responding. Has anyone tried using Sonic My DVD to convert the VHS to DVD? How were the results? Or if I go the TMPGENC route, what am I doing wrong. Also should I use another codec that will not create such large files on my harddrive?![]()
Results 1 to 9 of 9
I do know that TMPGEnc takes it own sweet time loading huge files, and sometimes it looks like it has locked up. Have you also tried Video Studio 6?
Hello. -
Tommyknocker,
I have not tried video studio 6. Do you get good results with video studio? I also want to keep the file size down. I do not have that much space left on my harddrive, even after purchasing a Maxtor 200GB drive. -
You are not going to get better quality downloads than DV. But you can go ahead and burn to a DVD with 65 GB file you have now to one DVD.
Hello. -
But you can go ahead and burn to a DVD with 65 GB file you have now to one DVD. -
DV captures are great! Wait until you see them! I use a program called Video Studio 6. I load the captured video, edit it, then select Create DVD. I install a blank DVD, decide whether or not I want a menu, and burn the DVD.
Hello. -
I would try maybe capturing in a slightly more compressed codec - the DV codec is around 13Gb per hour, or about 1/2 Huffy. See if TMPGenc handles a smaller size.
If so, go back and grab 1/2 hour of your tape, and see if TMPGenc can encode the original settings at a smaller size. If it can, then you can capture in smaller chunks and use TMPGenc to join them after encoding (much faster than joining the original avi files).
If TMPGenc can't deal with a smaller file captured with your original settings, then I would try another capture app and see if there's something with your configuration that is giving TMPGenc fits.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I would recommend trying what housepig mentioned. I successfully capture 2 hr- 3 hr movies in AVI using the DV codec with Scenalyzer Live! and encode with TMPGEnc after editing either with VirtualDub or trimming out commercials w/ avisynth.
Good luck! -
frameserve this huge file to TMPGenc!
Use virtualdub for this, it works excellent....
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 15:22 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 00:44 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
