when i capture to mpeg1 to burn to vcd, if the video bitrate is above about 2.5 mbps, when i play it on my dvd player the video plays slowly and jerky and the bottom half of the screen flickers sparatically. why does this happen?
Results 1 to 10 of 10
Originally Posted by xsbs52x
Use a lower bitrate -
no its probably that your dvd player can read XVCDS, but use a lower bitrate like 1868 as your max video+audio as that is the max for the mpeg 1 vcd reselution.
An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
Originally Posted by Cecilio
@xsbs52x, best bet is to make your VCD standard compliant by lowering bitrate to 1150 kbit/s CBR.
otherwise, first check out your player here: https://www.videohelp.com/dvdplayers to see if it plays xVCDs and the max bitrate it can support. -
I've captured as high as 2.24, they play on all 3 apex players fine, 500A, 500B, 1100W(the vcd capable one, not the later model). After seeing this picture quality, I am redoing my lower bitrated (x)vcds. Standard bitrates no longer acceptable. But still waitin' for dvd recorders to come down and get the bugs out.
Originally Posted by mopar7
2) price is already cheap enough. deals on DVD+RW drives end up being UNDER $100. DVD+RW media is generally more expensive, so i paid more upfront for a DVD-RW burner. i've seen DVD-RW drives (regular price on pricewatch.com) for as low as $129. with cheap DVD-R media nearly $0.80/disc, it's already pretty cheap.
only drives still expensive is the dual format drives, most of which are at least $200. however, that's still pretty cheap. -
Originally Posted by poopyhead
xVCD is NOT a "standard".
VCD max is 1150 according to the books of VCD.
BUT 1856k MPEG1 is the max supported in the DVD spec. Most DVD players can play 1856k, whether the info is on CD or DVD media.
Try to encode max VCD at 1856k.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
well my dvd player has no problem playing xVCD at 2.5 mbps, but at 3 mbps it plays slightly slower than it should. would i be able to use a higher bitrate with xSVCD? or would it still jitter at the high bitrate?
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 10:29 -
Caching files with high bitrate?
By therock003 in forum Software PlayingReplies: 5Last Post: 15th Dec 2008, 17:54 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
Why Does One Mpg Jitter and One Doesn't? And Why The Jitter?
By abrogard in forum Video ConversionReplies: 10Last Post: 17th Nov 2007, 02:21
