I've just tried using forty-two for the first time.
I've got a TiBook 667 running 10.2.6
I want to make an SVCD from a DVD image file created with CaptyDVD.
I mounted the disk image and dropped the DVD icon into forty-two v1.6, created a folder when asked, accepted the file name and created a temp folder. The SVCD button is selecetd. When I click start, I get an AppleScript error
AppleScript Error
sh:-c: line 1: unexpected EOF while looking for matching `"
sh: -c: line 2: syntax error: unexptected end of file (2)
I tried the same with a commercial DVD and get the same error. Any tips on what I need to do?
Thanks for any info.
Dave
remove all illegal characters in the path to your files. It could be that since you have a mounted dvd, if you have spaces in the name, or illegal characters such as : " ' & etc, thats its not going to recognize the file
also, ensure you have the utmost latest forty-two and that its installed proplery. (manually drag the folder called FORTY-TWO to your applications support folder (library/applicationsupport) and then run the build forty two support app.
with that said, and no illegal characters or spaces in the path it should work. -
Galactica
Thanks for the info. It looks like it's going to work.
No script error and disk info is displayed.
I'll give it a go, tomorrow.
Dave
AVISynth script error
By rvnwlf in forum Blu-ray RippingReplies: 1Last Post: 24th Aug 2010, 19:52 -
Script error message
By didikai in forum ComputerReplies: 2Last Post: 11th Jun 2010, 23:06 -
By rvnwlf in forum Newbie / General discussionsReplies: 0Last Post: 11th Jun 2010, 13:33 -
Apple Script Error
By shirokuma in forum ffmpegX general discussionReplies: 0Last Post: 21st Apr 2008, 00:46 -
Script error
By buddycat in forum Video ConversionReplies: 8Last Post: 18th Nov 2007, 07:38
