I just bought a dvd rewriter bundled with Nero 5.5 ..... Does this encode avi's to mpeg-2?
I have tried TMPGenc but it only seems to give the option for mpeg-1, which isnt good enough for what i want. Plus the fact that it says that the file I am encoding is way too big .. even though it isnt!
I am getting more & more confused with each day ..... any help would be greatly appreciated.
Thank you
Okay, yes nero can encode avi's to mpeg-2 but you have to have the mpeg2 plugin for nero ($) and the results will suck b/c nero is not a good converter.
TMPGenc is a excellent converter but if u want to encode to mpeg2 you will have to get the full version ($40 i think) the free version only allows mpeg-1.
a free mpeg2 encoder is bbmpeg, you may give that a shot if your looking to not spend money. -
As treebeard has said Nero is useless for encoding, TMPGEnc is well worth a $40 investment.
Tmpgenc dvd mpeg is not smart rendered by Nero
By perfection in forum Authoring (DVD)Replies: 3Last Post: 17th Dec 2008, 15:00 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
