i have a lite-on rom and a pioneer 105. when trying to copy a dvd using nero, on the fly, the dvd burns but when i try it in my player or on my computer there is nothing on the disc ?????? there appears to be something burnt on the dvd but nothing recognises it. its as if the lite-on doesn't read the original but the 105 burns a blank session![]()
Results 1 to 9 of 9
When you select File-->New and the Compilation screen comes up, if you select the Burn tab,does it look anything like this:
Hello. -
Make sure your burner is the selected drive and not Nero's image burner.
I don't have a bad attitude...
Life has a bad attitude! -
I don't use Nero for d2d copies, but you should use the 'DVD Copy' mode, seems to me.
i do use dvd copy mode and my pioneer 105 is selected as the writer. an image is burnt onto the disc but it appears to be blank. i also have easy cd 6 installed, could this be causing a conflict??? (the reader dosen't seem to be reading the original while the copier is writing)
Originally Posted by padster
Oh crap! Are you trying to make a copy of a hollywood DVD?
You do know they're encrypted, right? You can't make a copy "on the fly" using Nero. You have to decrypt it first.I don't have a bad attitude...
i'm trying to make a copy of a copy. the writer senses the size of the session and burns a blank session of that size on the disc. the reader dosen't initiate and read the track throughout.
i.e. dvdxcopy implemented "security features" one of which is to prevent you to copy the copy...to be more in compliance with DMCA and not piss off the MPAA even more. -
certain dvd copy programs prevents you to make a copy of a copy...for legal purposes... i.e. dvdxcopy implemented "security features" one of which is to prevent you to copy the copy...to be more in compliance with DMCA and not piss off the MPAA even more.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Only White Video appears
By 911alertme in forum ffmpegX general discussionReplies: 3Last Post: 1st Oct 2008, 17:44 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
NO sound when i try to burn in nero 7..
By lil_jayz76 in forum AudioReplies: 3Last Post: 3rd Nov 2007, 20:05 -
nero burn plus subtitle?
By mai_hnf in forum DVD RippingReplies: 1Last Post: 31st Aug 2007, 22:57
