  1. Trying to put dvd into one disc format to fit onto once cd. Using
    Smart Ripper to rip, DVD2AVI to create d2v file, TMPGenc 2.5 to encode
    d2v file so I can set it up to encode into one disc format. My Problem is
    that after creating the d2v file when I open TMPGenc 2.5 to encode the file
    I get message that the d2v file is unsupported. It will not open these files
    at all. The real poser is that I have gone through this process before, and
    had no problem what so ever. I have not changed any settings in any of
    the programs since I first did this. Can someone tell me why TMPGenc will
    not recognize those d2v files? Please help me with this. I am about to pull
    what little hair I have out!!!
  2. Are you opening the correct D2V (the new one created by DVD2AVI....not the one created by Smartripper)
    "Today is only yesterdays tomorrow"
  3. I take it you are trying to convert to vcd, why don't you use Eazy Vcd from the tools menu, it will do everything for you.
    If it's wet, drink it
    My DVD Collection
  4. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    I suspect you have to change the priority in 'environmental settings'.
    I'm not at home so can't talk you through it exactly, post back if you get stuck; I'm 99% sure this will solve your problem
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
