i need to put some subtitles onto an avi movie.i have followed the tutorials using virtual dub and vob sub.only problem is virtual dub does not detect the vob sub plugin......im not sure if i have to convert the AVI file to another format.(i have a .sub file that i want use).....any ideas
It depends on which version of VobSub you have. Version 2.18 has the filter, 2.23 does not. Go figure.
Hello. -
install vobsub again, 2.23 DOES have the plugin, you just need to SELECT to install it.
you need to press the plugins option while you install, and select the virtualdub plugin.
point it to the virtualdub folder and it will install the plugin.
and you might as well install the textsub plugin.
get vobsub here
http://kripton.cec.uchile.cl/Programas///VobSub_2.23.exe
it might get stuck on your screen after installation, so just kill the app.HELL AINT A BAD PLACE TO BE -
you could convert the .sub to .ssa with subtitleworkshop, and then use virtualdub's subtitler plugin (available on it's webpage) to add the subtitles.
.supfoo`
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28
