Hi! so i'm back for hlep once again.
I'm transfering some stuff onto dvds via my computer and a dv camcorder. so i bridge my vcr to my pc with my dv camcorder and a firewire card. i'm using either pinnacle studio 8 or sonic my dvd to capture. both have the probelms. and i believe u lead did as well.
most are doing fine. but some for some reason have what seem to be tracking problems. they play on my television fine. and i've even tried coping them and then putting on the computer but no go. it's quite annoying. adjusting the tracking does not work. auto tracking does not work. i've tried everything that i can think of. please help!
Robby.
Hmm, not usre what you mean by tracking problems but a common problem with displaying DV on a PC is due to interlacing. Your TV is an interlaced display. Your DV is interlaced, your monitor is not, so it does not display interlaced material well. Try playing the DV in PowerDvd, which has a built in de-interlace filter. If it looks ok in that, you are good to go.
it still looks messed up in dvd playing programs... it looks messed up on my lcd display on my camcorder...
tracking problems as in... like part of the screen is wavy. if that makes sense. -
Ah. ok, so its not DV tape, its DV as passthrough for a VCR, yes?
In that case I see what you mean, it does sound like tracking problems with the VCR. The VCR should have some sort of tracking adjustment, either a knob to turn (older models) or a menu option. If all it has is auto tracking then all I can suggest is try a different VCR, borrow one from afriend if oyu have to. In fact, as it shows up on your camera LCD, just take the camera and tape (nad cables) round to a friends house to try it. -
i've tried 2 different vcrs.
both play it fine on the tv. and then bad threw my camcorder...
the only thing i can think of is that it's the cable or something? but it doesn't do it to all videos. so i don't know. i guess i'll try a new cable? blah/.
VHS-C tracking problem
By chuna25 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2010, 00:23 -
Isolating/masking a video such as in photoshop or some sort of tracking
By Rudyard in forum EditingReplies: 2Last Post: 28th Oct 2009, 22:03 -
Problem w/Folder sort v1.1. Had to reformat disk
By cal_tony in forum ComputerReplies: 2Last Post: 24th Aug 2009, 16:25 -
nero backitup problem (sort of video issue)
By ecc in forum ComputerReplies: 10Last Post: 7th Oct 2007, 08:50 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
