I used Ulead DVD MovieFactory 2 and it converted the file and put them onto a cd what i have know are. 6 files
CDDA file
CDI file
KARAOKE file
SEFMENT file
VCD file
Are these the file i need to play it on a dvd player? can i just go put it in know? or do i have to do somthing else. Sorry, if a noob question.
If the disk has finished burning, why not put it in the player and see if it plays?
Hello. -
i did but it didnt work, but i cant really go by my dvd player bc right know its not one that can play cd/cd-r....you also dont have to be an asso about it.
Trust me, I was not being a curmudgeon. Second, tell me what kind of player do you have, and do you own a software DVD player?
Hello.
