Is there any way to put divx codecs on a dvd, so that the player and the codecs are already on the dvd, so basically i just want to watch divx/xvid with out installing anything on someone elses computer... has anyone ever done this, is it even possible
thanks
Ryan
You win some, and you lose some, and some get rained out...
Very confused post!
Can't decide which your trying to do from the post
1. Watch DIVX content on a DVD surface
If this if for your computer...Just include the divx codecs install folder outside the VIDEO_TS (video title set)
If this is for your settop .. GO TO DVD PLAYERS on left column here
and enter DIVX as search term... There are 1 or 2 brands of player that will play this content ( no codec required)
2. Put DIVX content into a DVD..These files need to be transcoded and authored befor burning to DVD otherwise they certainly won't play in almost any settop and
3. NO , the user will always have to install DIVX first -
thanks i thought that it had something to do with the reg....
thanks again
ryanYou win some, and you lose some, and some get rained out...
Common Codecs and xVid / DivX compatability
By anonymous_whatever in forum Newbie / General discussionsReplies: 25Last Post: 20th Feb 2012, 17:53 -
Multiple Divx codecs?
By Huh...What? in forum Video ConversionReplies: 15Last Post: 16th Dec 2009, 08:44 -
divx codecs for Philips DVP5160/12
By petarone in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Jun 2009, 21:04 -
Xvid and Divx Codecs
By Jomapil in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 10:42 -
Same Codecs but cant be played on the same divx player
By weeleong87 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 12th Jul 2007, 13:06
