I've 3 files which is CDI format and need to burn it out, Nero don't recognise the files. Any of u can tell me how to convert to AVI or MPG.
Please Help me!!! Thank You
I think .cdi is an extension used by DiscJuggler. I don't know if DiscJuggler has a functional demo version or not. Alcohol 120% can probably burn them, but I don't know about its demo version either. If you do a web search you should be able to find a free program called cdi2nero that may be able to convert it to a native Nero image for you.
Thank you sterno.... as per ur guide, i managed to burn out as vcd already through some tutorial over the web.
Many Thanks,
Looking for a converter
By zf1223 in forum AudioReplies: 5Last Post: 28th Jan 2011, 21:03 -
converter
By buzzyy in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2010, 00:32 -
HD Converter
By Stevo1975 in forum Newbie / General discussionsReplies: 2Last Post: 27th Feb 2010, 18:48 -
RM Converter
By imero in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2007, 20:44 -
Need a converter that can do this...
By rindless in forum Video ConversionReplies: 2Last Post: 7th May 2007, 05:15
