Hi,
I encoded a DVD vob clip with Mainconcept to a MPG file but I get no audio.
How can this be fixed, if at all?
what was the source audio ? did it show a source audio in the audio source window?
what did you pick as type of output?
yes - you can 'fix" it // just rip the audio stream from your vob file and use it -
Input= C:\WINDOWS\Desktop\New Folder\VTS_01_1.VOB
Output= C:\WINDOWS\Desktop\New Folder\VTS_01_12.mpg
No audio source to pick from.
I used dvdshrink and cropeda 40meg section of a backed up DVD.
It created the vts_01_01 Vob file.
I used that as the source and I can not figure out how to get the audio extracted from it. -
it is most likly ac3 audio (im guessing).
demux the ac3 from the vob , convert the ac3 to wav , use wav as source .. -
or remux the ac3 w/ your new mpeg file you created (im not sure what your doing with it)
Thanks for the info.
It is AC3 audio. I am trying to put it on a DVD and a VCD.
What I am doing is grabing sections of movies out of my backed up DVD's and putting them on a VCD to play at work and also a DVD for home.
I'm a little confused on the Remux part. Can you explain how to do this from the Mpeg I created?
Thanks again
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 20:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56 -
MainConcept H.264 Encoder Error
By cowboysroy31 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2007, 19:06
