Another newbie problem here. I am having trouble ripping a double-sided DVD while using smartripper to rip as dvd movie, key search set to once. However the ripping process cannot even begin as the key search just keeps going and going. After about 5 minutes, I get the error no key could be fund to decrypt the dvd. Is this a problem with only double-sided dvd? The other single-sided dvds in the same box set have been ripped without any problem. Should I try to rip and encode without keysearch? Any help would be great.
when smartripper fails, try dvddecryptor...the combination of the 2 hasn't failed me once.
Same damn problem I get. The key search thing seems to fail. How important is it anyway. I think I can rip by disabling it. It's ok to then encode?
yes, you need to decrypt the DVD as it is encrypted and you will not be able to view it otherwise.Originally Posted by Weevis
o heh...i almost forgot....right before you're about to rip the DVD, first play it in your software DVD player (i.e. winDVD/powerDVD) for a minute or so...then pause it...then use your ripping proggie to rip it.
google search pages keeps erasing my search criteria -- [RESOLVED]
By vhelp in forum ComputerReplies: 0Last Post: 5th Mar 2011, 16:27 -
Complex chroma key matting problem
By Morality124 in forum EditingReplies: 33Last Post: 7th Nov 2010, 15:36 -
Search Excel Spredsheet Data in Vista Search
By mn072065 in forum ComputerReplies: 11Last Post: 29th May 2009, 00:26 -
Change the key of a song to another key?
By Ikka in forum AudioReplies: 4Last Post: 3rd Feb 2008, 13:27 -
TDVD08 and 4GB USB Key problem
By hemyd in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Aug 2007, 11:53
