  1. hello there
    im quite new to this and this has probably been asked before but i couldnt find it if it has.
    what is the easiest way to put three movies on one disc with a menu.
    i thought it wasnt possible but recently ive got a hold of some multi's that are near perfect quality.
    i thought you may have to use divx, but the discs i heve arent.
    Thanks for your help.
    Jul 2003
    i think it is done on a dvd recorder that you can buy to record eastenders and stuff . you just link it up to your dvd plyer and just play then record what you are plaing in the other . then record the next one after
    hope that helps
    simz
  3. Member cplevel42's Avatar
    Feb 2003
    mrsoul, welcome to the site!
    1st of all, there is NO way to put 3 full movies on a DVDR with almost perfect quality. Divx or Xvid is the only file that would come close to your description and that would have to be raw divx or xvid files being played back on a Kiss DVD player or computer.
    You could do 30 minute episodes though. Is this what you mean?
  4. thanks for replys
    well ive not got a clue how the disc is done, but my mate has got the three austin powers movies backed up onto one disc and the quality is superb.
    i thought you could maybe convert them to divx then put them on disc with a menu using roxio or tmpgenc
    cheers.
    Jul 2003
    is the menu on a blue screen with about 8 rows
    with prev play next at the bottom
    if so its the same as the ones ive got as i said before i think they are copied on a dvd recorder they can copy up to 6 hours on one dvdr i have got some and at the start you can see the vcd logo at the top of the screen
    but you only get the same quality that you are watching
    simz
  6. no the menu is just a black screen with pics of the three films to choose from
