  1. Hi,
    I have been battling for some weeks trying to convert NTSC video from my camcorder to PAL. With the help from many informative articles on this website I have managed to get the video side of the conversion working really well. I am using avisynth 2.5 to frameserve to TMPGec Plus.
    My original posts were to the Audio forum and Bugster has been helping me with the audio side but now I am wondering if I have done something wrong with the video conversion, hence the post to this forum.
    Here is my avisynth script ..
    LoadPlugin("D:\Applications\Mpeg2Decoder\MPEGDecod er.dll")
    LoadPlugin("D:\Applications\SmoothDeinterlacer\Smo othDeinterlacer.dll")
    MPEGSource("D:\pdwork\ntsc.mpg", -2, "raw")
    SeparateFields()
    ConvertToYUY2(interlaced=true)
    Weave()
    SmoothDeinterlace(doublerate=true)
    #ConvertFPS(50)
    ChangeFPS(50)
    LanczosResize(720,576)
    SeparateFields()
    SelectEvery(4,1,2)
    Weave()
    ConvertToRGB()
    The resulting video stream is very smooth, way better than any NTSC to PAL conversion I have been able to do before.
    The problem I am having is with syncing the audio to the video stream. I have tried BeSweet and Goldwave to change the length of the audio but whatever I try nothing ends up synced up. The closest I can get is if I multiplex the original (ntsc.mp2) audio stream to the converted video stream (.m2v). The multiplexing is being done using TMPGEnc.
    I can't figure out why I need to change the speed of audio. The converted video ends up exactly the same length as the original so why do I have to stretch the audio?
    Here are some details on the various files I have managed to created so far:
    1) Original NTSC source (filename: ntsc.mpg)
    (info from preview in TMPGEnc)
    720x480, 29.97fps, 112323 frames, total length 01:02:27 (1hour 02 mins)
    2) video converted to PAL using avisynth/TMPGenc (filename: ntsc2pal.m2v)
    720x576, 25fps, 93695 frames, total length 01:02:27
    3) Original audio stream, extracted as MP2 from ntsc.mpg using TMPGenc (filename: ntsc.mp2)
    (info from Goldwave)
    total length = 01:02:27.912
    4) Modified audio in WAV format (using 'warp' feature in Goldwave) (filename: ntsc2pal.wav)
    total length = 01:14:12.150
    5) Above WAV file encoded to MP2 using TMPGenc (filename: ntsc2pal.mp2)
    total length = 01:14:12.168
    Can someone please tell me which audio stream I should be muxing with the converted video? I cannot see how any of the stretched audio will work as the length is completely wrong, but all the articles I have read in this and the Audio forum say that I need to go through some stage to change the length of the audio.
    Also, has anyone been successful in using avisynth to simultaneously convert the video and audio streams? I have read that there is a plugin for avisynth that will allow the audio stream to be imported,
    thanks,
    Kevin
    Feb 2003
    Waltham, USA
    I don't know what you did with audio stuff, but I haven't seen anywhere about your chanign the framerate of the audio as well. If you're audio is still at ntsc, you'll need to change it to 25 fps (PAL). I usually use Besweet and it works fine. Once your audio as been "re-framed" you should be able to mux the video and audio in sync.
  3. thanks for your reply.
    Yes I have done the frame rate conversion for the audio for NTSC to PAL. The two files I created are described in my original post (files 4) and 5) )
    These both end up with a different length to the original and also the converted video stream. Is this right?
    Maybe there is sonething that is missing from the step I am doing in Goldwave. Maybe I have to do some sort of frame rate convert whilst maintaining the original length?
    I previously tried BeSweet to do the audio frame rate convert but had the same problems, i.e. converted audio length much too long.
    I have followed the proceedures gigevin in the Besweet conversion guides found on this web site, I guess I must still be missing a step somewhere.
    Can you help answer the fundamental question:
    Should the converted audio be the same length as the original audio stream from the NTSC mpg?
    thanks,
    Kevin
    Feb 2003
    Waltham, USA
    How come in you framerate change your specifiying 50 fps?
  5. To be honest I don't know why it is there, I just copied it from a conversion tutorial I found on this site. All I really changed was the file import as I am importing MPEG for my run.
    My problem is that most of these tutorials deal with NTSC film, DV conversion. None that I found cover conversion from NTSC video (29.97) to PAL. Also the audio steps usually deal with conversion from AC3. I have really struggled with this (I'm fairly new to this conversion stuff incase you hadn't already guessed).
    Anyway, as the converted video looked good (played in WINDVD) I assumed all was well.
    Do you think I should re-run the video conversion without the ChangeFPS(50) ?
    Kevin
