  1. Does anybody know of any programs, that can transfer .mid music files into .mp3 music files?
    When Im using Sibelius it sucks to have to listen to my creations in .mid
    Please help, thanks.
  2. I know WinAmp with MP3 output plugin can do it.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  3. Originally Posted by hellfire104
    First find a program which outputs a good midi sound. The one possibility is Wingroove. Then output to a wav file. Then compress with the LAME.
    The simplest option -- Play the midi in your player. Record with GoldWave or whatever at 44kHz (at least). Save the wav and convert to mp3.
    BTW if you have the LAME ACM codec installed you can save directly to mp3 from Goldwave.
    Best wishes,
    UP
  4. Um......what is LAME??
  5. Originally Posted by hellfire104
    a free mp3 codec
    by the way, the very famous not only because it's free but because of the nice quality
    Best wishes,
    UP
