This is my problem:
I would like to show potential customers my dvd creations. I would like to take my main menu page which has moving picture, some clips and put them onto cd, Because cd is just so cheap. I would like to show them a sample of what I can do.
Is there a way to take from my dvd my main menu page and clips and extract them to cd?
Please help
Corey
Have you considered playing your DVDs on a software DVD player in full screen mode, then recording it with a screen capture program like SnagIt!?
Hello. -
maybe you could author it as a miniDVD?
check here : https://www.videohelp.com/minidvd.htm
I would make a main menu for my creations with submenus that take you to each project.
let's say I had 3 projects I wanted to show off - I'd have a main menu with each listed, then a secondary menu for each project, with the stuff you want to show off and some truncated clips from the projects.
maybe that would work?- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
Want part of DVD to one file
By neworldman in forum Video ConversionReplies: 1Last Post: 30th Apr 2010, 18:38 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
How to cut out a part from DVD?
By DjuKa in forum EditingReplies: 8Last Post: 23rd Oct 2008, 11:03
