Is there any shareware or anything out there that can be downloaded to export an image from a mpeg movie. I have ULEAD Media Studio Pro at home and ca do it with the Video Paint option, but I am using my PC at work and just wanted something small and qucik, since I will not leave the application installed once I get done with this project. Any help would be appreciated. Thanks
Results 1 to 9 of 9
Well, the trial version of WinDVD or PowerDVD may be functional long enough to capture an image.
Hello. -
I'm not sure if we are talking about the same thing here. I don't want to play the movie and do a screen capture. The application I am used to can take a movie and hash it out frame by frame, and you can select a frame and save it as an image (jpeg). I want to be able to take a MPEG video, go frame by frame and extract an image from the video. I need the image to use in a menu for the SVCD. Thanks for the help!
I do not that if you are playing a moveie in PowerDVD on WinDVD, if you press the camera button, a JPEg or bitmap gets captured of the scene. Is this what we are talking about?
Hello. -
PowerDVD 5.0 lets you play frame by frame and capture exact frame you need. Also you can do it with VDub + DVD2AVI, which is a little complicated.
Thanks....but I found a good application now...
It is called CapturEx Image Grabber. It works perfectly. Thanks for the help. i have PowerDVD installed but I do not know of a camera button to press when watching a video. -
Originally Posted by Watyeag
Hello. -
TMPGEnc is the best picture ripper for your purpose. yuo extract any frame you want as a JPG. it is not a player with a capture button but a picture extractor.
Export Functions under MPEG Streamclip
By kannixpert in forum Video ConversionReplies: 0Last Post: 10th Feb 2011, 11:40 -
Audio not synced on Export from MPEG Streamclip
By Luckyword in forum Video Streaming DownloadingReplies: 0Last Post: 1st Nov 2009, 17:45 -
MPEG Streamclip question: which is better? QT DV or Export to DV?
By Direwolf in forum MacReplies: 8Last Post: 29th Jan 2009, 11:38 -
FCP6-No longer possible to export Mpeg-2 from timeline?
By stretchweider in forum MacReplies: 4Last Post: 15th Jul 2008, 18:33 -
Export as Mpeg or AVI
By markannab in forum Authoring (DVD)Replies: 2Last Post: 19th Jul 2007, 21:32
