Is there any program that can do it FAST and stays under 4,4 GB?
I tried using Ulead DVDWorkshop, but it will take about a day (maybe more, I cancelled the job)
[EDIT]
Sorry!! Could you move it to the right section?
It sounds like Ulead is re-encoding the video for some reason because it shouldn't take that long if it isn't. Is your video dvd compliant? If it is try changing the settings on the program to get it to not reencode your video. I've never used it, so I can't really help you there. You could also try using ifoedit to author your video. guide here https://www.videohelp.com/forum/userguides/120013.php
VOB files too fast/out of sync in Vegas Pro 10.
By rcavanah in forum Video ConversionReplies: 7Last Post: 10th Sep 2011, 20:14 -
After MPEG-PS conversion, beginning of the video is extremely fast
By killazys in forum Video ConversionReplies: 7Last Post: 24th Jun 2010, 00:22 -
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 04:06 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 21:48 -
Question on conversion from VOB files to MPEG4
By donkeyking in forum Video ConversionReplies: 8Last Post: 17th Jul 2007, 16:56
