I have followed the tutorial for SVCD to DVD a few times on multiple movies hoping it was the movie, but it isn't. For some reason when I put the DVD+RW into the DV-250, the screen flickers and it is in black and white. VCDs have played fine but SVCDs have not. I was wondering how I may fix it. Please Help..
BTW. According to the compatibility the DV-250 SHOULD play svcds.
SOunds like a NTSC/PAL problem.
Which format is the source video?
What svcd to dvd method did you use? What tools and settings. -
The original file I am going from is an SVCD. But I am trying to make it into the DVD video to play on the DVD player, since nero, ulead, etc won't let you burn SVCD to DVDs. Therefore I am following the https://www.videohelp.com/svcddvdr.htm tutorial. I followed the tutorial step by step.
Hmm.. I just put the DVD in my DVD-RW to make sure it was going fine and it only shows half the screen. Kinda weird EH? I'm not sure why that is. When I open the original it displays it all the way across. It seems to be cutting the movie horizontally.
Plasma flickers when used as a monitor
By joe7dust in forum DVB / IPTVReplies: 16Last Post: 26th Nov 2012, 14:42 -
Sumvision Cyclone Micro 2+ menu flickers!
By Cieran in forum Media Center PC / MediaCentersReplies: 0Last Post: 24th Nov 2011, 20:44 -
DV footage flickers when converted to DVD!
By Duck_Plumber in forum Newbie / General discussionsReplies: 11Last Post: 17th May 2010, 02:43 -
Screen flickers after updating my Asus BIOS
By Hittz in forum ComputerReplies: 8Last Post: 18th Feb 2008, 02:38 -
Black upper stripe flutters / flickers
By dynamique in forum Authoring (DVD)Replies: 0Last Post: 26th Sep 2007, 07:05
