hi there got a bit of a problem svcd2dvd+ wont work for me i have the right version of besweet installed and in the right place but when it gets to elementary streams just sticks and doesnt do anything else i am desperate to get this programme working can anyone help
t
trinity12345Guest
i think we need a bit more information to help. can you send the version window of svcd2dvdmpeg and a screen dump of the window it hangs on.
trinity12345Guest
it was my fault i had the besweet exe file in the besweet folder but did not extract everythimng to that folder hence it wouldnt work . sorted the problem and works like a dream
thanks
chrissyboy for a good time saving programme no mor worrying about audio sync problems after waiting for 3/4 hours with other programmes lol
trinity -
Henry_DHGuest
Muxing elementary streams hangs with two audio streams or more in author DVD.
BeSweet only processing one mp2.
Batch seems buggy -
Henry that seems to be you cause i can run 8 vcd through it without troubles.. what version of besweet are you using..
Henry_DHGuest
I tried both latest beta and leatest stable of BeSweet. Second audio stream is is unused in file folder.
When mps are re-muxed with Tmpeg to one audio stream SVCD2DVDMPG+ works fine -
Yes Henry_DH only mpegs with single audio streams work at the moment. Once my menu adventures are over I will address multi audio stream mpegs.
3 movies, 6 elementary streams, 1 DVD
By Pholder in forum Authoring (DVD)Replies: 1Last Post: 5th Aug 2010, 09:51 -
Multiplexer for elementary streams for a BD-R / AVCHD
By BobaFett77 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Jun 2010, 17:59 -
demux a .mp4 to elementary streams
By halsboss in forum Video ConversionReplies: 4Last Post: 28th Nov 2009, 17:38 -
How do you join elementary streams?
By rayden54 in forum EditingReplies: 0Last Post: 5th Jan 2008, 21:43 -
From DVD VOBs to proper elementary streams
By gabier in forum Video ConversionReplies: 9Last Post: 28th Nov 2007, 22:48
