How do i select the correct aspect ratio for my divx files. Like if I encode to MPEG2 at 352x480, I can select it to display at 4:3 aspect ratio correctly. How do I do that with Divx?
I use virtual dub to convert. Do I need another program to do this?
Originally Posted by LanEvo7
Eg 640*480 = 4:3. (and lots of other combinations too!).
Hope this helps -
If you download the Divx player, you can adjust the aspect ratio of Divx encoded files. I haven't used it in a while, but it's easy enough to find. You can encode to something like 352X480 and set the aspect ratio to playback as 1:1, 4:3, or 16:9.
Not really fixing the aspect ratio, but it does provide a workaround. -
Oh well. I figured I could compress more video into my dvd if I could change the aspect ratio.
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
Star Trek 4:3 Aspect Ratio manually set to 16:9
By cowboyup910 in forum Authoring (DVD)Replies: 8Last Post: 17th Aug 2010, 10:15 -
Can you set aspect ratio in 'Any video converter free version'
By Rudyard in forum Video ConversionReplies: 2Last Post: 7th Apr 2010, 00:26 -
How do I set the aspect ratio so pics look right on my new LCD monitor?
By johnsees in forum Newbie / General discussionsReplies: 26Last Post: 11th Oct 2008, 00:58 -
Change/Set aspect ratio in AVI file
By cheerful in forum Newbie / General discussionsReplies: 9Last Post: 7th May 2007, 17:28
