Hi....any ideas would be great....this is getting annoying.........
I had a 4 gb harddrive running in my computer as the primary master
(I was using it as a backup since my 60 gb crashed). I unplugged the
4 gb because the 60 gb has been fixed, and plugged in the new drive.
I changed the setting in BIOS, and tried to start it up. No luck....it would
boot, and does the very beginning stuff (doesn't try to access the
a:\ drive...which it should), and then just goes to a black screen with
a blinking cursor in the top left. So, i put back in the 4 gig, and reset
the BIOS settings for the harddrive, and get the same thing. What gives?
I keep getting this stupid cursor. I can't get to anything.....Windows, the
floppy disk....nothing! Has anyone had a similar experience?
Thanks!
Results 1 to 1 of 1
Slight prblem with noise.
By Jimbo1 in forum Video ConversionReplies: 1Last Post: 25th Jun 2011, 08:57 -
Slight Hauppauge HD PVR Issue
By octaneflame in forum Capturing and VCRReplies: 4Last Post: 10th Feb 2011, 16:46 -
Slight EMERGENCY! Please help with editing .SDV files!
By Carppacio in forum Newbie / General discussionsReplies: 4Last Post: 30th Nov 2010, 18:18 -
Slight problem with GOM Player
By jonghyunchung in forum Software PlayingReplies: 1Last Post: 22nd Oct 2008, 02:04 -
Slight problem when hardsubbing in a batch
By bmwracer in forum Video ConversionReplies: 1Last Post: 25th Jun 2007, 17:32
