Hi, Im adding 6 AVI files into the timeline and producing 1 mpeg file is there anyway to make it play as one instead of going back to the menu everytime (in moviefactory it lets you specify if you want to carry on to the next one) I cant seem to find how to do it
steve
Hi,
In the 'Menu' section right click on the videos you have cued-up at the bottom of the screen. The after play option allows you to decide whether or not to return to the menu or play the next video in the cue.
Mark -
Thanks for your reply but it doesnt make any difference, it is ticked and it wont even let you deselect it Perhaps i should try reloading the prog
thanks
steve
DVD Workshop 2 - No Audio in Windows 7
By KTH in forum ComputerReplies: 3Last Post: 27th Dec 2010, 16:08 -
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 22:05 -
DVD Workshop 2: Where is the best tutorial for this project?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2010, 09:09 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 09:16
