Hi all,
Please can anybody tell me where to find a guide showing how to create a menu. Basically i have some cartoons on vcds (3 eps on each disk) and i want to make them work better by having 1 screen when you put in the vcd. This screen to show a pic from each episode numbered 1, 2 and 3. All you need to do is chose 1, 2 or 3 on your remote and the relevant episode starts.
thanks
What buring software are you using? I make text titles with Nero, but never tried pictures.
VcdEasy can do that, very easy to use. Just play around with it and you probably won't need any guides, or if you do, it's in the guides section here. If you search online, you can also find the freeware version.
Originally Posted by fmctm1sw
Cannot get multiavchd to create menu
By Yanta in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Feb 2012, 23:29 -
multiavchd, create menu?
By volam1 in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Jul 2010, 13:31 -
Create Menu with 2 or more pages
By Phototechman in forum AudioReplies: 2Last Post: 15th Feb 2010, 09:37 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36 -
Create new menu to link to existing menu. Possible?
By Noy2014 in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 12:22
