How do I create a multimedia CD-Rom that includes
1) Audio tracks
2) Data (eg: shockwave presentation)
3) VCD
and make sure a regular cd player plays back music, a hardware vcd player play the video and a computer run the multimedia data.
Need urgent help.
You can definitely put additional data files on a VCD. VCDImager, VCD Toolkit (I think), Nero and ?WinOnCD allow you to do this.
VCD2.0 also supports CD-DA audio tracks. I think that only WinOnCD and VCD Toolkit support this functionality though.
Regards.
Michael Tam
w: Morsels of Evidence -
You can probably burn the audio tracks first. Close Session (not Close Disc). Then burn a VCD (containing your extra data files - Nero can do that). Or vice-versa.
I never tried it myself, but you can always give it a shot... -
I havent seen one piece of software that supports each and every capability of VCD 2.0. I'm kind of hoping VCDImager will step up to the plate.
VCD Toolkit and Videopack 4 will allow video and CDDA audio, but no extra data files.
Nero and VCDImager will allow video and extra data files, but no extra CDDA audio. -
Jeomite, what you described cannot work. VCD2.0 is very specific on exactly where certain things go phyisically on the CD.
Regards.
Michael Tam
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 18:17 -
VCD / Audio / Data in only ONE CD!
By demonlhama in forum Authoring (VCD/SVCD)Replies: 9Last Post: 15th May 2008, 10:53 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 16:15 -
Vcd + data simple project
By wilsoncortez in forum Authoring (VCD/SVCD)Replies: 13Last Post: 30th Jun 2007, 00:06
