How to produce a high quality DVD from Mini DV? I tried with hp dvd writer software, quality just sucks, may be the options I have selected was wrong??
I tried with Pinnacle studio and bbmpeg, bit better but still big difference from original DV quality. or may be my settings are not accurate???
Some people are suggesting TMPGEnc software to convert from AVI to MPEG-2. I downloaded and installed, but it says it was expired. I might have played with it some time back. How should I get around with this?
It says
MPEG-2 Encoding function has expired
The free version of TMPGEnc can supply only 30 days limited MPEG-2 Encoding function because of MPEG-2 licensing matter.
If you wish to use unlimited MPEG-2 encoding feature and more, "TMPGEnc Plus" is available for sale! ...
I know it has been discussed at various places in this forum, but I was so tired and confused reading all the threads. If any one can give me direction, that would be great. THanks.
[/b]
hey
get TMpgenc off their official website - it shouldn't be expired.
<please read rules - do not promote warez>
it does an amaaaazing job encoding Avi files to Mpeg 2
good luck
bmwstylz -
you dont "get around it" you purchase it b/c your trial period is upI might have played with it some time back. How should I get around with this?
Getting it off of a P2P network is not a legal way to obtain the mpeg2 encoding functions of TMPGenc.Originally Posted by bmwstylz
Dont ask for warez, or suggest getting warez -
Your going to get yelled at if you ask for a way to get around the trial limit.
MainConcept has a free trial. http://www.mainconcept.com/downloads.shtml -
I am sorry I didn't mean that. I thought we can install MPEG 2 feature from other sources and use TMPGEnc with that encoder. And also everywhere people mentioned this one as free, so I thought this could be the way.
anyway I am looking for quality conversion tool, should be same as my DV quality. Which option is the cheaper without losing the quality and where can I get it? -
If quality is what u seek then TMPGenc is probably the best choice, however u will have to get the full version for DVD (mpeg2) encoding which costs $40 (i think). the free version is just for VCD (mpeg1 encoding)Originally Posted by eluck
I think the only free mpeg2 encoder is bbMPEG, look in the tools section under video encoders.
best HD editor for producing DVD
By mtrax in forum EditingReplies: 14Last Post: 12th Aug 2009, 04:59 -
how to enhance sound qaulity of dvd clips from security cameras
By sydneynewbie in forum Newbie / General discussionsReplies: 15Last Post: 4th Apr 2009, 06:36 -
How to Mini High Definition (m-HD) like those guys uSk, vaLk, TlN50p, gRg.
By Disty in forum Blu-ray RippingReplies: 2Last Post: 10th Nov 2008, 20:00 -
Toshiba RD-XS35 producing a relatively high amount of bad/weird burns
By Bix in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Sep 2008, 12:25 -
Qaulity Capture Card for VHS-DVD & Computer TV Viewing/Capturing
By RubicksCube13 in forum Capturing and VCRReplies: 1Last Post: 11th Nov 2007, 09:00
