I downloaded a movie and burn it on a CD. They tell me that a SVCD so good, my player can support this, but I inserted my CD in my Sony and it's display VCD but nothing start, when I press PLAY it's say "Reading Impossible"
I try in my computer, work fine.
What's the problem ?
I check on the CD and there a MPEG2 file in a DIR, if I copy this file on a DVD-RW , do you think I will be able to play the movie ? or I need to convert......
My player is a Sony 725p
Thanks!
Results 1 to 9 of 9
I would extract it from the disk and re-burn it as an SVCD with nero or another program. The standard SVCD isn't just a folder with a mpg in it. The burning program converts it to a dat or bin file. I'm not sure which.
How did you encode the movie? What type of file was the original file that you downloaded? What program did you use to encode the file to SVCD format? Did you use TMPGenc? If so, what option did you choose under MPEG Settings on the system tab as the stream type. Make sure it is set on MPEG-2 Super VideoCD (VBR) if you want to create a SVCD.
It looks like your player is compatible to play SVCD's. I have Sony DVP-NS755V dvd player and it plays SVCD's very good. -
Originally Posted by AMD2400
If I open the disk I see 4 folders :
EXT
SEGMENT
MPEG2
SVCD
in MPEG2 I got the AVI
Do you think I need to re-encode ? with a specific program ???
Thank
FTSHARK: I think I will try your method too , I give you some news. -
Originally Posted by symetric
BTW, you cannot just copy an SVCD file to a DVD-RW, the formats are not compatible that way."Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
Originally Posted by symetric"Art is making something out of nothing and selling it." - Frank Zappa
did it also have a .cue file?
if not, copy the mpeg2 to HD and reauthor an SVCD like others said.
SVCDs use 2 Tracks, The .cue file sets it up, otherwise they dont work in stand alone DVD players.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Originally Posted by Ejoc
Which program I sould use to re-author the mpeg ?
Thank
My Sony CD/DVD player (NS55P) would almost only play sony discs.
By valdes001 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2011, 10:03 -
Sony M2TS to Mpeg2 on La Cie Hardrive cannot play ?
By WARRANLAMB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 14th Oct 2009, 04:48 -
Can't play MP3s on my Sony DVP NS355 DVD player
By harrylentil in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Aug 2009, 14:04 -
Windows Media Player dont play mpeg2
By mogoyon in forum Software PlayingReplies: 4Last Post: 14th Jan 2009, 13:31 -
Would i be able to play a pal dvd with a sony blu ray player
By fceurich in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Feb 2008, 09:47
