I have been having problems with the sound on VCDs I authore myself on my Samsung SV-DVD1E
there is a clicking noise every 10 seconds. I capture the video with virtual dub as divx using the version 4.01 codec, then i use tmpeg to convert it into mpeg, i use the VCD template in tmpeg , if i use the SeVCD template it works fine on my pc but if i play it in my samsung the picture breaks up .
The VCDS i make using the SeVCD template works fine on a Lasonic DVD player but not on my samsung.
If i use the VCD pal template the picture is fine just problems with the sound.
I use nero to burn the VCDs and have tried several brands of CDR
Any ideas anyone
