Hi!
I've posted a similar topic earlier on, but I haven't been able to solve my problem so here I go again.
I've followed the guide here https://www.videohelp.com/tmpgencdvd.htm on how to make a DVD and everything is fine except the audio. It is very metallic and poor after having used Virtual Dub.
Does anyone have a suggestion on how to improve the audio?
I'd be grateful for an answer.
Nille
I think you capture audio in 44100 MHz, when DVD audio is 48000 MHz. When you let TMPGEnc convert the 44100 MHz audio file onto 48000 MHz, it will - for some unknown reason - get this metallic sound.
You can avoid this if you convert the 44100 MHz audio file onto 48000 MHz with for example CoolEdit Pro. Then you'll get good sounding audio.
I use TMPGEnc to make a WAVE file of the captured file.
Hope this solve your problem.
-Scandic-
Making Someone Look Bad :)
By HoosierGuy in forum EditingReplies: 9Last Post: 16th Dec 2011, 14:37 -
Popcorn MKV AudioConverter is making bad audio, alternatives?
By _ck_ in forum Video ConversionReplies: 3Last Post: 28th May 2011, 14:57 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Making dvd with audio files only
By ian c-nall in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2009, 07:19 -
No audio after making DVD
By Dark Mirage in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 3rd Mar 2008, 15:47
