has some cool enhancements..now even easier to use..no "AutoShrink by Dummies" book required.
http://www.mrbass.org/dvdshrink
Results 1 to 14 of 14
i keep getting a run time error when i start autoshrink - please can you advise.
dlb. -
runtime error....specifically what?
btw 1.3 is out
Skip 1:1 option added. -
Have found this tool to be very easy to use
Would be nice if it remembered all settings . i.e whether overwrite re-writable disc check box is ticked or not
Otherwise a great little prog -
letitbleed,
I can do that will do it on my next release 1.4.
energy80s
What this program does is:
1. Determines if the DVD can fit on 1 DVD...if it does it will create an ISO image and burn with DVD Decrypter automatically.
2. If DVD is too large to fit on 1 DVD or you choose to Skip 1:1 then it will launch DVD Shrink...And burn upon completion using ImgTool.
3. You can Label your own DVD or it will generate your label from original DVD -
Nah.
'Specially since I've just been using AnyDVD and dragging the files from one drive to the other and hitting "burn".
- Gurm -
I have a dvd9 in drive A and a dvd-r in drive B.
I start auto dvdshrink and I get a warning dialog box with the fillowing message:
Run-time error '339':
component 'COMDLG32.OCX' or one of its dependencies not correctly registered: a file is missing or invalid.
I press okay and the program closes.
I have all the files in the same directory.
dlb. -
version 1.4
Save Settings no longers exits entire program
Save ImgTools Settings is implemented -
dlb,
It appears you are missing that DLL. See this site if you have ?'s about it.
http://www.cd-ripper.info/faqs.htm -
nyplayer
Can't believe you have updated Autoshrink so quick (3 times in one day) !!!
Nice to see you listen to suggestions & where possible implement them
Keep up the good work
One other suggestion,as you are updating so regularly the GUI is becoming a little 'cluttered' -
Thanks nyplayer, problem solved.
will test out proggie tonight after work.
dlb.
ffmpegX 0.0.9y released
By major in forum ffmpegX general discussionReplies: 12Last Post: 28th Nov 2008, 01:39 -
MacDVDBitrateParanoia v0.5 now released!!!
By bendermac in forum MacReplies: 12Last Post: 29th Apr 2008, 15:10 -
ImgBurn v2.4.1.0 released
By louv68 in forum Latest Video NewsReplies: 2Last Post: 1st Apr 2008, 13:18 -
Ubuntu 7.10 released
By Baldrick in forum ComputerReplies: 10Last Post: 26th Oct 2007, 10:41 -
OGGCConv 1.02 Released
By lindoran in forum Latest Video NewsReplies: 0Last Post: 14th Jul 2007, 23:43
