I am capturing a few different t.v. shows that I plan on putting onto a dvd in the future, but for now I would also like to keep them on my pc and watch them from there. My question is if I encode these files to an xvid or divx for now, when I later re-encode them to be put on a dvd, will the quality be worse than if I saved the original large capture file and encoded for the dvd from that? What I really need to know is if I should save the original capture avi in addition to my smaller, encoded files that I make with virtualdub. Thanks in advance for your help.
3 posts on the same topic seems to be enough...
The answer to your question is yes. Each time you encode the quality will go down a little depending on the amount you recompress it. It would have better quality if you kept the original but sometimes that isnt possible. -
nyijedi, please do not post the same question in multiple forums.
I can understand why you were not sure where to post this, but if you find yourself in a similiar situation in the future just pick one forum. If it is considered to be the wrong one, then a mod will move it.
Your other two posts on this subject have been closed.
File types and DVD player
By rogmath in forum Newbie / General discussionsReplies: 10Last Post: 7th Jan 2011, 14:24 -
Putting different types of file formats on to DVD-R
By carl606 in forum Newbie / General discussionsReplies: 10Last Post: 11th Mar 2010, 05:11 -
Which DVD Player For Under $50 Plays Most Downloaded File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 10Last Post: 6th Jan 2010, 14:55 -
Problems conveting several file types like RMVB and MP4 etc
By tommyleepark in forum Newbie / General discussionsReplies: 6Last Post: 21st Aug 2009, 18:55 -
Blue Ray player file types
By plasmannc in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Dec 2008, 18:32
