  1. I bought a Dazzle DVC-80 along time ago, now i got a dvd burner and i found my old dvc-80 but i have no box or software so i tried using myDVD (came with dvd burner) but it wont detect the dvc people on the net have said to use moviestar 5 but i can't find my cd. Any freeware programs i can use?
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    check the Capture software in the Tools section at left.
    I like iuVCR, but VirtualVCR is also good. VirtualDub is one of the standards for capture, but if your capture box doesn't like it, try VirtualVCR.
    FreeVCR is also an option - I haven't used it in a while, but it seemed okay.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
