i have an AVI file dat i wuld like to make it into a MPEG...but first off...i can't view a lot of it...when i tried to check w/ VDub it saids something like
"AVI:Index Not Found or damaged -- reconstructing via file scan"
"AVI:Invalid Chunk detected at 10185426. Enabling aggressive recovery mode."
Then the AVI file would only open the first 2-3 minutes which is the good portion of it...
can some1 help?
you have an incomplete file and part of it is corrupted.
open in vdub. let it recuild index. the go to video on the menu and have it scan for bad frames after it is complete the save the file as avi but you must use direct stream copy for audio AND video. the new saved avi will now have an idex and be error free and you can do what you want with it. -
when it was scanning...it only scanned the good part...and wen i saved and played it - it only played the first like 2-3 minutes and it saids the file was 2-3 minutes
man...is this troublesome... -
you could try divfix and it will locate the bad frame and put out a log file thenyou could manually delte them in vdub
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 16:22 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 11:31 -
lagarith avi to xvid avi - problem
By phpmysql348 in forum EditingReplies: 1Last Post: 23rd May 2008, 13:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57
