Hello,
basic question here. Why does captured video always show a thin distorted line on the bottom of the video??? You know, like it's all scrambled and as if the tracking is screwed up.
How can I get rid of that? The only way I have been getting around it is by cropping with Premier or something of the like, but that slightly distorts the entire image as well. THere has to be a way of capturing the video without getting that messed up line.
thanks ahead of time,
ress.
if you are going to play the capture back on a TV, you can probably not worry about it - most of that area is going to be lost once it's played back because it's outside of the display area of your tv screen.
if you are going to play it as a computer file, you can crop it out - as it's only a few pixels high on average, it shouldn't distort your file too much.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
housepig,
any idea why that happens though? and yes I am going to brun a cd so cropping for now is the only way to go.
thanks,
ress. -
If it's off of tape then it's a matter of poor signal tracking/stability. It's a common problem that can be solved with additional costly hardware. Do a search on TBC ( Time base correction ) to see how it's fixed.
name/cause of this video distortion?
By spiritgumm in forum Newbie / General discussionsReplies: 8Last Post: 29th Mar 2012, 11:24 -
Distortion in audio
By carlmart in forum AudioReplies: 2Last Post: 3rd May 2011, 13:59 -
DVD Distortion on TV
By Craig Taylor in forum Authoring (DVD)Replies: 1Last Post: 2nd Apr 2011, 04:25 -
Bottom line distortion when capturing Hi8 with passthrough on DCR-HC40E
By kvortman in forum Capturing and VCRReplies: 9Last Post: 22nd Mar 2011, 00:28 -
Audio distortion
By silveringking in forum AudioReplies: 0Last Post: 26th Jan 2011, 16:13
