Hi i'm a newbie here..... but i have loads of questions to ask...
please i'm begging that anyone who wants to help me, explain
your answers to me as if you are explaining to a child...i'm not that good
at computers as in... literally...
anyway...
basically i need help on creating a vcd
i dont know what are the tools...
(i have VCD gear, ISO Buster please tell me what else i need)
i just recently ordered copies of vcds from the philippines...
i tried playing it on oritron 200 but it failed. so it copied it to a regular CD-RW and punch in the secret menus and worked really good on my DVD.
well... my question is...
#1.) how come when i copied the whole CD to a CD-RW, it worked fine on my oritron 200... however, if i just burned it as a data file to the CD-RW, it didn't work....
#2.) when you open a regular VCD what/how should its format look like??????
this was how the VCD that i got looked like....
+ CDI
-Cdi_imag.rtf
-Cdi_text.fnt
-Cdi_vcd.cfg
-Cdi_vcd.app
+EXT
-Lot_x.vcd
-Psd_x.vcd
-Scandata.dat
+MPEGAV
-Avseq01.dat
-Avseq02.dat
-Avseq03.dat
+SEGMENT
+VCD
-Entries.vcd
-Info.vcd
-Lot.vcd
-Psd.vcd
#3.) is there any possible way that i could watch avi on dvd player???
or how could i put an avi file into a vcd format?
should i just convert the avi into mpg and then burn it as a data
and then play it on the dvd player?
thanks in advance...........
MistaFOBulos@aol.com
I think you should read here:
https://www.videohelp.com/vcd
and here ,first:
https://www.videohelp.com/convert#vcd"Today is only yesterdays tomorrow"
Subtitle Creator error: Input string not in correct format
By kpic in forum SubtitleReplies: 6Last Post: 31st May 2013, 03:17 -
Very Basic--> What format to work with Final Cut with my HD cam.
By Mcjuicypants in forum EditingReplies: 0Last Post: 5th Mar 2011, 20:55 -
The correct format for a movie to play on a Bluray player.
By hardhatmac in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Mar 2010, 17:53 -
Cutting down video and correct format for Windows Media Player
By bpatters69 in forum Video ConversionReplies: 1Last Post: 9th Nov 2009, 17:27 -
Correct settings for encoding video for the 'new' YouTube format?
By Captain Satellite in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2008, 17:45
