  1. I have never had a problem like this before...
    I get the VOB's from the DVD and put them into DVD2AVI. The movie worked fine as a saved project. When I tried to do any of the extras as a saved project it would only come out with a .d2v file, no .wav file? Does anybody know what the problem is?
    If everything is infinite then nothing is definite.
  2. 1) could be the extra has no audio
    2) try switching to another audio track
    what you can do to test is to select an audio track and then press f5.. an info box will appear...just look in the audio section for a DD. if the audio section is blank, than it means there's no audio in that particular track u selected. then select another audio track and repeat.
