Results 1 to 10 of 10
  1. I have been capping and encoding for about a year so I consider myself
    to have a medium to above average knowledge.
    I wanted to improve my encode just that little bit so I used these setting
    Vid
    Average 2486
    min 1000
    Max2586
    Audio
    192
    Total bitrate= 2778 which is the standard. But when I cut the file using bbmg (muxed file etc) it get a message that the video and audio bitrate are too mhigh and might not play correctly.....I use CCE for my encode can anybody see what Iam doing wrong or is it that I am not using a "standard rate" for audio and video???
    How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
    If you like Tekno download one of my tracks
    www.users.bigpond.net.au/thefox149
  2. I should state that I normally use 224 audio and 2520 video
    which onlt equals 2744 ...maybe my setting are to close to the standard which doesn't allow for any mass fluction in bitrate..but the max setting should determine the absolute highest bitrate at any one time
  3. You forget that there is a small amount of overhead bandwidth you need to allow for when you multiplex the streams together. That is why it tells you it is too much, you should back off the video max about 25 or so and that should be enough.
  4. DVDjunkie your are a legend......
    would you say that
    192 audio
    and 2552 video is safe
    Upstate NY
    It's just something to try and see.... I usually set mine to 2550/160 and don't have a problem, but 2600/160 complains ( but plays fine )
  6. I never had it complain on my previous settings only and underflow complain but I have never seen that cuase any probs..
    Thanks guys I will stick to my settings before
  7. would you say that
    192 audio
    Yes that is almost certainly safe within specs. Your initial settings are almost 99% safe as well, as most players will handle slightly above specs, but for best compatibility keep within the specs.
    Mar 2003
    Laredo,Tx
    look the Fox149 its not too much bitrate you can use 5000 video and 448 for audio, and it still isnt enough, its just a matter that your player can handle it. im pretty sure there is no problem with your original size. just ignore the inquiry.
    An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php
  9. I am converting a wedding video so compatibility is a must....
    Needless to say to get it to work on this customer Player I have to use the VCDheader trick ....so I know that the machine could quite possibly handle files that are above the "standards" ...but for future the custmore might wanna copy them etc and it would cause less probs if they are within a given spec.
  10. Member DJRumpy's Avatar
    Dallas, Texas
    The error may simply be due to the fact that the original SVCD was designed for a max bitrate of 2496 kbps to keep bitrate low enough to meet the DVD Player standard read rate for CD-R.
    BBMpeg is probably complaining for that reason, although I agree with everyone else. Your player will probably play it without issue. If your worried, just keep your video max to 2496. I would think the visual difference between 2520, and 2496 would be inivisible to the viewer.
    Impossible to see the future is. The Dark Side clouds everything...
