I have a movie split into 3 clips all encoded with Xvid codec
They are all 23.976 FPS
I separated the audio to .wav
The first clip went falwlessly
But the second clip is 3 times bigger (700mb) and the TMPGenc always fails changing it at the same spot
I got Vdub Mp3 and followed Tender's guide
I scan the movie for bad frames but Vdub Mp3 fails the scan at the same spot every time
I would really like to get this to work
What can i do?
Results 1 to 22 of 22
I deleted some of the bad frames myself
But when i save the avi it becomes an enormous file and i have to stop it because i wouldn have enough space on my hard drive
Can i delete some of the bad frames out of the Xvid encoded .avi and Save it back as an Xvid encoded .avi? -
Another Update
The bad frame in the video is so bad that when i try to pass it going frame by frame Vdub freezes and needs to be shut down.
What can i do to fix this bad spot in hte video -
Originally Posted by Cutmaster87
8)"Art is making something out of nothing and selling it." - Frank Zappa -
when you cut those frames out make sure you select direct stream copy so it will only be as big as the file you already have
Originally Posted by Cutmaster87"Art is making something out of nothing and selling it." - Frank Zappa
Here's what I've done in your situation......
Cut the video into two parts, Part A is before the glitch and is in sync, Part B is after and needs fixing.
Extract a wav audio file from each part, I use Goldwave but if it's not AC3 or VBR-MP3 then you can use Vdub.
Use Vdub to remux the wav audio into part A: load the part A avi, select wav audio, set video and audio to direct stream copy, save avi.
Use Goldwave to adjust the audio in Part B: cut a portion if it lags, insert silence if it leads
Use Vdub to remux the wav audio into part B (see above).
Test the audio in part B and readjust if necessary. When you are satisfied with the results you can join parts A & B with the Append Avi function in Vdub.
If you need more details just ask. Good luck! 8)"Art is making something out of nothing and selling it." - Frank Zappa -
OK first question what should i split it with?
And am i supposed to cut it exactly before the bad area?
The audio is wav so i dont have to worry about that -
OK i Split it by selecting the area and i saved the segmented avi is that right
If you mark the very beginning of the movie, and then right up to just before the glitch, then "save segemented avi" that'll save part A.
If you then mark right after the glitch, and then the very end of the movie, then "save segmented avi,' that'll be part B.
BTW, be sure to have the audio and video set to direct stream copy.
Then reload part B Avi back into Vdbub, audio full processing mode and save wav to extract."Art is making something out of nothing and selling it." - Frank Zappa -
I cant do this AHHH
I fixed the audio in part A which was cut before the bad area but the end it has about one second of audio pulled from it
Part b has the 1 second of audio from A on the video so the video is lagging the audio
Im thinking about giving up
I have gone this far should i go on -
Keep going, you're getting close.
If you join the two parts (append avi) does it work?
If not, then extract a wav from each avi, use Goldwave to fix the wav's (cut from one, add to the other), remux the wav's back in the avi's, join the avi's.
I'll check back tomorrow."Art is making something out of nothing and selling it." - Frank Zappa -
Wait i have an idea
Can i take the audio from the movie with the bad frames out sav it as a .wav
and add it to part a and b while they are being put together?
SOunds crazy enough to work for me -
gold wave is really hard for me
any way you could help me in the cutting and pasting
How do i know the exact spot
And how do i put the audio there -
OK i think i found the exact spot where the audio stops in Part A
14:01.383 and the end of part a is 14:07.514
so should i find the difference and take that number away from part B audio -
Im giving up i finaly got the part after the bad frame audio synced after cutting and asting for 3 hours and when i joined the two movies together the audio is off altogether forget it Ill just wait for the dvd
Also, under Tools and device controls is a control box for playing the file. You can locate your markers and play the file back at any point, that can help to locate the part where you want to cut/copy.
Good luck!"Art is making something out of nothing and selling it." - Frank Zappa -
It really is no use, there are more errors in the video and it would take forever to fix them unless there is some other way to cut frames out
I hear you. Sometimes it's just not worth it!
Thank you very much for all your help though
You were very god at guiding me through
AVI (xvid) into TMPGenc plus HELP
By efiste2 in forum Video ConversionReplies: 3Last Post: 4th Dec 2010, 17:30 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Help converting a Xvid to DVD with TMPGEnc 4.0 XPress
By ozzhead42 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 14:01 -
Xvid to svcd + burn...
By Crapozo in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2007, 05:07 -
xvid files act weird in TMPGENC
By briansmccabe in forum Video ConversionReplies: 4Last Post: 11th May 2007, 22:53
