I'm having problems getting captured video (from VHS or TV) to DVD. No matter what I try to do, the movie comes out bad quality on the DVD. Even after all my reading articles and guides, the best I got was still a little blurry and hard on the eyes.
I'm capturing into Premiere 6.5 with a Canopus ADVC-100. I go into Premiere because I need to edit the clips. I then export using LSX Encoder plugin for Premiere straight to DVD standard video. I don't think the problem is in the authoring or burning as that doesn't touch the video right?
I think the problem might be in the capture quality because LSX is pretty straight-foward on the DVD standards except I was a little uncertain as to what interlacing settings to use. I think I figured out the interlacing by making a test DVD just to compare effects on the video.
Please let me know what I'm doing wrong or what I can do to improve quality. Any information would be very helpful. Thanks.
hard to say - "bad quality" doesn't really translate - can you get some screen grabs and give us examples?
especially if you can grab a frame from the source, and then the same frame after you encoded, so we can see what's bad.
but yeah, the authoring and burning stages shouldn't affect the video quality, unless your burner is set to reencode files with it's own encoder.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I'll work on getting a screen grab tonight. Whats the best way to do that? Take a screen shot? or export a frame?
Have PowerDVD or WinDVD screen capture. If you have a website, you can give us the link.
Hello. -
depends on your system - exporting a frame is usually more certain, since some screen-grab software will just show you the player with a black screen, due to the way the video card handles video files.
- housepig
Housepig Records
out now:
Sorry for the delay, but I've got some screengrabs now. I can post more if its needed. I posted shots of the raw capturre and the compressed MPEG. I exported these shots out of Premiere.
Warning: Each shot is about a meg.
This shot should be pretty detailed but its all blurry.
http://www.andrew.cmu.edu/~bpilnick/DVDShots/CapturedAVI1.bmp
http://www.andrew.cmu.edu/~bpilnick/DVDShots/DVDMpeg1.bmp
This shot shows what happens when the camera pans past something or something moves quickly. That blurring is present every few frames.
http://www.andrew.cmu.edu/~bpilnick/DVDShots/CapturedAVI2.bmp
http://www.andrew.cmu.edu/~bpilnick/DVDShots/DVDMpeg2.bmp
Just showing the overall "bad-quality"
http://www.andrew.cmu.edu/~bpilnick/DVDShots/CapturedAVI3.bmp
http://www.andrew.cmu.edu/~bpilnick/DVDShots/DVDMpeg3.bmp
After looking at frame comparisions, it looks like the loss in the capture. Any suggestions?
F4F capturing/converting
By konverter in forum Video Streaming DownloadingReplies: 348Last Post: 22nd Nov 2017, 04:07 -
Getting the most out of 30 fps when capturing/converting
By CursedLemon in forum Video ConversionReplies: 4Last Post: 26th Apr 2012, 10:11 -
Suddenly now problems converting/burning .flv videos?
By gastrof in forum Video ConversionReplies: 2Last Post: 8th Apr 2009, 13:22 -
Converting and burning problems with iDVD 7.0.3
By stormrider76 in forum MacReplies: 5Last Post: 14th Mar 2009, 08:51 -
.Rmvb Converting/ Burning DVD problems.
By evan11567 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2007, 01:35
