hey guys,
i'm new to the whole capturing thing...anyway, i'm converting home movies to dvd and wondered what the best program would be to adjust things like brightness and contrast and things like that with MPEG2s...thanks!
TMPGEnc has the max flexibilty -little bit tricky getting it to accept mpeg2 though!!
many capture apps will have the capability to adjust brightness & contrast at capture - I would say if you have a video you think is going to need adjustment overall, do a couple of short test captures while changing the capture controls, until you find a good setting.
then capture the rest of the material.
I think you may find, if you have extensive editing to do, it'll be easier to capture as an .avi and edit, then reencode to mpeg.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I like Video Studio 6. Captures, edits, menus, and burns.
Hello.
help me improve the video quality of my game trailer with avs video editor
By DapperDave in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2012, 01:06 -
Which video editor should I buy?
By vidds in forum Newbie / General discussionsReplies: 9Last Post: 5th May 2011, 18:11 -
What Video Editor are you using?
By nickmind in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 46Last Post: 9th Oct 2010, 09:58 -
The right video editor
By dgarmaise in forum Authoring (DVD)Replies: 3Last Post: 25th Mar 2008, 13:21 -
New Video Editor
By DragonXD in forum EditingReplies: 3Last Post: 2nd Dec 2007, 14:01
