After going through the menus of DVD2SVCD. I then goto rip and convert on the conversion tab. The program says preparing vobfiles to be ripped. After about 10mins, I get this message
I/O error 103 The operation completed successfully
What am I doing wrong?
Thank you
Corey
You're most likely not doing anything wrong.
Sometimes the ripping function of DVD2SVCD has trouble unlocking the DVD in your drive.
There are 2 things you can do for this.
First, put the DVD in the drive and play foe a few seconds in whatever software player you have and then start the DVD2SVCD process again.
(If you don't have a software player then download a free or trial one fro the tools link on the left side of this page.) Playing it unlocks the protection and saves the ripper a lot of trouble.
Second, you could try ripping with SmartRipper and then just tell DVD2SVCD what folder you used to save the ripped files. This is the method I always use because SmartRipper seldom has trouble and it tells you up front if it is having troulbe as well as what the trouble might be.
Either way should work.Only 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy -
Oops! I jsut re-read your post and you are getting the error 10 minutes into the rip.
It sounds like the comand line ripper in DVD2SVCD tripped over a problem on the DVD that it couldn't deal with.
I would DEFINATELY now go to the SmartRipper method. SmartRipper is a bit more robust in getting past source DVD problems.
Good LuckOnly 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
