first let me say im a moron and i appologize. i din't read the rules well and im a moron. I admit it. it'll never hapen again i swear. next, to anyone having this problem with downloaded VIDEO FILES. if you download a video file and it will play in wmp but won't convert in tmpgenc and g-spot says its not an avi file, try using dvdtoavi and encode the video with divx or something. it should then encode with tmpgenc. i hope this helps anyone out there who has any problems with downloaded video files.
Results 1 to 14 of 14
hmmmm nar didnt work, it wouldnt let me resave the avi, must have a buggy avi then
damn was a good movie too, if you find any other ways to fix it a reply would be apreciated
thanx for trying though -
it didn't let me save it first either. in dvdtoavi when you save, it has an option for recompretion. the default setting is no recompress. click on that and it will bring up a bunch of codec options. try different thing as the codecs you have may be bad cracks that wil decode but will not encode. keep trying till you find one that works. also, you might try opening virtualdub and recompressing another more encodable files as it will tell you what codecs you have are good for encoding and which are not. post back and let me know if this works for you.and dont as anyone else about wares as you can get stupid people like me in trouble.lol.
also, did you use g-spot to se what codecs it requires and if so what did it say?
nar i didnt use gspot, but i can play it in win media play n stuff, i dont think its a codec prob, with dvd2avi it doesnt let me select save avi at all so i cant get to the compression stage.
first of all. my movie played in windows media player to. second go to the tools section an get g-spot. its an incredibly usefull tool to tell you exactlly what codecs you need. i've hade problems before with encodeing movies that would play in wmp but wouldnt encode in tmpgenc and it was because i had enough codecs to play but not to encode. if that is your case, g-spot will tell you. if g-spot says that the file isnt an avci file, then use dvdtoavi. and as far as not leting you save, does it open and let you preview it? if it does, then click on file and save avi. when you do this, you will see no recompress. if you choose this, it wont save and the box on the right will say finished imediatelly. you need to change no recompress to another option. if you have divx 5.02 then try that. if you don't have divx 5.02, then that might be your problem. post back if you have a prob.
that dvd2avi thing didnt work, it wont let me preview the file or anything, so it must be an avi because dvd2avi opens files like mpeg2 and vob m2v etc. ill try the virtual dub mpeg2 thingo now
ok, if it wont let it preview it then it is an avi and you dont have the same problem as me. go get g-spot and open the file and see what it says. i had the same problem as you about the same file as you and it had to do with the codec. turned out i had enough divx to play but not enough t encode. g-spot will tell you everyting. go get it im telling you.
yep im downloading it now, im downloading divxfix too just to see if that does anything
oh, gspot says my avi is a mpeg, maybe its been renamed .avi
divxfix also says its not an avi, so i dont have an avi
normally when i have a mpg in the properties it has the name of the file then (mpeg) -
then you do have the same problem as me. when i open it with g-spot, the type says non avi file- type unknown. the video at the bottom says mediasubtype mpeg2_video and the audeo says mediasubtype mpeg1audiopaylo. all the other boxes for what codecs it uses are filled with n/a. by the way. i hope you realize that in dvdtoavi when you go to open a file, you might have to select all file types to see the file and select it, but once you select it, if the little black screen changes sises then it will work. to see if it wil word, you have to hit preview and then hit DISPLAY. if you see a picture, then go and make sure you have the divx pro codec pack version 5.0.5 . then you can use dvdtoavi to encode it into divx. also, when you select divx 5.0.5 to convert with, select configuration and tweak the bitrate settings. if you do this right, it will work very well with no side affects. i didnt think dvdtoavi was working for awhile thill i realised you had to hit display (f7 i think).hope that helps, if not then im stuck but i hope g-spot helps you. it helped me.good luck.
you can have a avi with mpeg , avi is just a wrapper -- there are more than 40 types of uncompressed and compressed avi files .
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
Mpg to fixed avi size.
By jjulio1 in forum Video ConversionReplies: 12Last Post: 8th Mar 2008, 14:59 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07 -
DirectShowSource prob for AVI(DV) to MP4
By sekaiji in forum Video ConversionReplies: 3Last Post: 29th Jun 2007, 18:43 -
avi to mp4 with MeGui prob...
By sekaiji in forum Video ConversionReplies: 2Last Post: 29th Jun 2007, 16:48
