Ive encoded heaps of avi's into mpeg before and never come accross this problem before.
I open avi2wav to create a .wav file for my avi and attemp to open my avi and get this error message "File blah.avi not AVI!" Blah is the location and name of the file.
So i decided to try create the wav file with virtual dub. There are two parts of the movie involved in this operation and when i open both with virtual dub the mpeg import filter appears and displays that its parsing VideoCD Stream.
I can create a wav file with the first part, but with the second, the mpeg import filter appears like the first part except about half way through an error message appears saying "MPEG Import Filter: packet sync error on packet stream (12fee164)"
I dont know whats going on so if anyone does could you please help solve my problem
Thanx.![]()
Results 1 to 11 of 11
Sounds like you may have a .mpg file RENAMED to a .avi file. Have you tried using TMPGenc to de-multiplex the audio?
Go to the Tools section at left and Virtual Dub MPEG-2 AC3 mod.
Hello. -
im not to familiar with demultiplexing, whats it actually do?
Separates your video into a video file and an audio file.
Hello. -
what do i do with those two separate video and audio files, encode them in tmpgenc like i would with a vid file and wav file?
if so whats that suppose to improve? -
Please, download the MPEG-2 mod of Virtual Dub. It gets rid of the "MPEG Import Filter: packet sync error" error.
Hello. -
mpeg-2 mod may work but it didnt help me with my problem. i needed to use dvdtoavi.
go get g-spot i tell you. it will tell you everything you need to know about the file you have and what you need to encode it properlly. when you get the right codec, it will tell you codec is installed. when you don't have the right codec, it will say its missing codecs and is playing on winn media player via direct draw. if this is the case , you will be able to play it but not encode it. but when you go get the codec it says to, you will be able to encode it with no problem. try it.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 23:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 05:03 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
