  1. i have just put togther a Xdvd and when i play on PS2 it plays in black and white and in a fastest speed
    i have played them on the ps2 before will no problems
    does anybody have any ideas please
  2. you got it to play on a PS2?? how??
    i have a newer PS2 (6 months old) and it won't play my SVCDs
    did you use a boot disk? or will it just play them?
    thanks
    BMwstylz
  3. just authored another 1 and plays fine that was using dvd lab so hopefully i might have sorted the problem out
    it just plays them
    what software and disks are u using m8y
  4. software - Nero to burn mpeg2s
    discs - phillips CDs
    it ain't work tho!!!
    man this video making sh*t is f*king frustrating!! grrrrrrrr
    bmwstylz
  5. Originally Posted by wilson22
    i'm surprised you can even get an xDVD to play at all, since it's a non- standard compliant DVD
    if you're having problems with xDVD, have you considered making a standard DVD...or would that be too much of a hassle.
    look here: https://www.videohelp.com/dvdplayers.php?DVDname=sony+playstation+2&Search=Search
    clearly states that PS2 can't play VCD, xVCD, SVCD, and CVD
