Hi,
I can't capture files larger than 2GB.I have a Hauppauge Wintv-Pci capture card,a 866 mhz pentium machine with a dedicated capture disk of 20GB and a 10GB system disk.I also have 256 mb ram and i use the capturesoftware (wintv32)that came with the card.I have a Windows2000 ntfs installation.
Can someone please give me some answers because i'm tired of joining files.
Use Virtual Dub Dude record in segment =)
Feel my Power Flaming Black Dragon Wave!!!! -
in win2k ntfs-partitions u do have the 2gb filesize-limit. i think u turned on some 'compatibility mode' in virtualdub. only use "F5" to capture video, not "F6", ok?
-Elchknie -
It might be the software you are using. WinTV might not allow higher than 2GB files. Maybe they believe most people run FAT32? Use VirtualDub *without* the segementing option. See if that works.
FFDSHOW won't install on Win2k
By DanielF in forum Software PlayingReplies: 7Last Post: 27th Apr 2013, 06:12 -
Missing or corrupt file in Win2k
By bevills1 in forum ComputerReplies: 8Last Post: 10th May 2008, 21:43 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 14:23 -
windows explorer in win2K
By fjmr in forum ComputerReplies: 10Last Post: 4th Oct 2007, 18:37 -
What does win2K need for WinMediaPlayer9 to work ?
By DBenz in forum Software PlayingReplies: 2Last Post: 1st Sep 2007, 12:21
