I'm still disapointed by the video support Mac's have these days (no good MPEG2, slow encoding, etc.).
I was woundering would this change on MacOS X?
Is there a good video support on other UNIX based OS's?
These programs will probably be easy to port to MacOS X, right?
A friend of mine has a PeeCee with ATI RADEON card with 64 MB DDR. He can capture Video or convert DVD (or any other movie type)to MPEG2/1, Divx, or other codec in real time at any setting .....................
I want this! But I don't want a PeeCee.
Is there going to be any change with MacFLASK?
And if so when will it be released???
Mark,
The Netherlands
Have your heard of the "Wired4DVD" Mac PCI DVD hardware card? Does I belive what the PC cards do and plays DVD's. It sells for less then $100. in USA if you shop around...
Not able to encode realvideo with ffmpegX on MacOS SnowLeopard
By oicram in forum ffmpegX general discussionReplies: 2Last Post: 10th May 2011, 15:55 -
Unable to install ffmpeg in Mac G5 MacOS Leopard
By oicram in forum ffmpegX general discussionReplies: 4Last Post: 8th Aug 2010, 10:17 -
Frameserve on MacOS??
By Maxwellbest in forum MacReplies: 5Last Post: 4th Oct 2008, 17:34 -
Any body know to delte the ACrros using A MacOS X?.
By vriosm in forum MacReplies: 2Last Post: 8th Nov 2007, 08:55 -
Extract tar file in MacOS
By Simpleeme88 in forum MacReplies: 2Last Post: 30th Jun 2007, 06:14
